January 16, 201015 yr i bought my bike as an unfinished project its xvs 125 the previous owner has removed the indicaors an switch gear i have a complete wring loom for a xs 250 it comes with switch gear an all indicators what will the easyest method of fitting them be the loom on my bike has been chopped in the past i dont know what any of the wires are for could i wire the xs ignition switch loom to a live an then just chop off what i dont need or is there an easyier way ?
January 17, 201015 yr Moderator easiest way would be to get a xvs loom. the xs250 will be nothing like it, as it carries different electrical components due to its age!!
January 17, 201015 yr Author easiest way would be to get a xvs loom. the xs250 will be nothing like it, as it carries different electrical components due to its age!! i gave looking for a xvs loom they are rarer than hens teeth could i not use run a live to the switch gear an wire it that way
January 17, 201015 yr Moderator i gave looking for a xvs loom they are rarer than hens teeth could i not use run a live to the switch gear an wire it that way would the xvs250 up be better? have you tried here
January 17, 201015 yr Author would the xvs250 up be better? have you tried here thanks for that but i reckon it wont be cheap also the ignition switch startter horn an both lights are on different switches so i would have to rewire all these all i really need is a simple wiring diagram to show how the switch gear is wired to the indicators ?
