January 15, 201016 yr Evening all, Any ideas on lightening the clutch on an fzr 400 3tj? I've made sure the lever isn't fouled up, that the cable runs free and isn't kinked/snagged on anything, cleaned and greased the lever mechanism and screw thread, even taken the basket to bits and made sure everything is seated and free of burs and damage...yet when i build it back up its no better. I took the chance whilst it was in pieces to replace the plates and springs with the specified parts but still its made no difference...at the lever the pull is very heavy for what i'm used to with a cable operated unit, so i'm open too any suggestions on what the issue may be. Any ideas? Many thanks...Gizz.
January 15, 201016 yr Evening all, Any ideas on lightening the clutch on an fzr 400 3tj? I've made sure the lever isn't fouled up, that the cable runs free and isn't kinked/snagged on anything, cleaned and greased the lever mechanism and screw thread, even taken the basket to bits and made sure everything is seated and free of burs and damage...yet when i build it back up its no better. I took the chance whilst it was in pieces to replace the plates and springs with the specified parts but still its made no difference...at the lever the pull is very heavy for what i'm used to with a cable operated unit, so i'm open too any suggestions on what the issue may be. Any ideas? Many thanks...Gizz. had the same problem with my FZR600 3HE , i took all the burrs of the clutch basket put it all back together ,and it was still the same , so i put a new cable on and its fine , im not saying it is your cable but its worth giving it a shot, it could be bent pushrod or you have lost the steel ball which goes at the end of the transmission main shaft found this if its any good My link cheers Al
