January 14, 201016 yr Ive got an fz600 and im unsure if my tank has a leak or if theres a blocked breather or vent. Im also unsure if the tank is single or double skinned. I assume that the pipe that comes from the front of the bottom of the tank is on overflow of breather pipe this pipe seems to seep petrol (or it could be condensation and petrol im unsure) I was wondering if anyone has had the same or similar problem. It was suggested that it was a twin skin tank and the drain was for condensation from between the skins. i.e if there was a hole in the inner skin then condensation and petrol would come out of the drain. any help would be appreciated.
