yamaha xt125 2009 help needed urgently
hi there all i have a serious problem i went outside this morning and somebody has attempted to steal my bike i found it laying on the floor 100 meteres down the road with the little silver bit off the ignition where you put the key in missing and now my key wont even fit into start it
when i turn the bike also it stops when i turn it to the left i think the steering lock is broken can anybody please tell me if
they have an ignition bit for the bike or a steering lock ive been told 2007 and 2008 models fit but i cant find any anywhere
also does anybody no if other ignitions fit my bike
any help would be much apprecciated
john
Been there my friend you have my sympathies, the little silver bit is just part of the ig and i would expect that to be had it now. You may be able to change the lock barrel but if it wont accept the key its difficult.
As to the sterring, i take it you cant turn the bars to the left? The st lock is not really very strong and has more than likely been damaged.
It sounds like a couple of oiks having an oppotunistic swipe at the bike. I would get yourself a big lock as they will in all likelyhood come back once its fixed.
You need to have the lock etc to bits and work from there, is the steering lock on the headstock or part of the switch.
thankyou for your reply the steering lock is on the ignition what would i have to change or would i have to remove it so the bars can turn freely
john
