January 1, 201016 yr hello to all the members im just wondering if anyone can help ive recentley brought a xt125x 2007 stolen recovered the tank was of and the fuel pipes from carb to tank missing, pipes from carb to manifold were missing please can anyone help with any positions of the fuel pipes many thanks deano
January 1, 201016 yr if you looking for replacements google some bike salvage yards or ebay might do some or try http://www.yamahascooterspares.co.uk/spares/default.asp they do most geared yam bikes contact them to see if they can get hold of one for you.
January 2, 201016 yr Moderator Not familiar with the bike in question but I guess there are two pipes from the fuel tank tap, The larger one will be the fuel feed to the carb and there will really only be one spigot large enough to take it. The smaller one will be the vacuum line and will either go to a spigot on the carb that is positioned 'engine side' of the throttle slide, or will be connected to a spigot on the inlet manifold. Hope that helps...Paul
