January 1, 201015 yr hey guys my bike is always flooded when i try starting it the carb seems to be blooded no matter how much manual chock i use it does help the engine to start up what could be causing this?
January 1, 201015 yr Author haha im sorry was late as i had got back from night shift my bike seems to be blooded when i try starting it no matter how much manual chock i use it doesnt help and the bike remains flooded what could be causing my carb to be flood?is it the carb or could it be worn spark plug?
January 1, 201015 yr Moderator haha im sorry was late as i had got back from night shift my bike seems to be blooded when i try starting it no matter how much manual chock i use it doesnt help and the bike remains flooded what could be causing my carb to be flood?is it the carb or could it be worn spark plug? is the bike rideable...why do you think the carb is flooded...(what symptoms)?
January 1, 201015 yr Author well the engine ticks over but doestn wanan start up it takes ages for the engine to come on as its always flooded no matter how much choke i use when trying to start it it wont stop bein flooded so im guessing the carb is flooded. or the chock cable is to stretched and might need changing so its not closing the valve because its stretched?
January 1, 201015 yr Moderator well the engine ticks over but doestn wanan start up Well thats not right because its already started up when it "ticks over" it takes ages for the engine to come on as its always flooded no matter how much choke i use when trying to start it it wont stop bein flooded so im guessing the carb is flooded. or the chock cable is to stretched and might need changing so its not closing the valve because its stretched? You only need the choke to start the bike, gradually take it off as soon as possible after the engine is running, using the choke too much or for too long will give the symptoms you describe. Give it a good run get it warmed up with NO choke and it should be OK
January 1, 201015 yr Author ok thanks mate will try that hmm plus was very cold last night too so that might be behind it aswell haha as you can tell im not very good in the mechanical side of bikes.
January 9, 201015 yr i tihnk what he means is that it will crank over on the starter but not run under its own power, if it wont start pull the choke out until it will, but i never need to use the choke on my DT even on days like today :/ (but mines running rich anyway)
January 13, 201015 yr Author i tihnk what he means is that it will crank over on the starter but not run under its own power, if it wont start pull the choke out until it will, but i never need to use the choke on my DT even on days like today :/ (but mines running rich anyway) thanks thats what i meant
