YBR125 Custom gear selector issue
Hi there,
Is it possible to change the gear selector on a YBR125 Custom? Have always found it to be a bit short and too low as I have, to put it politey, big fat feet. Have just purchased a set of bike boots and this has now exaggerated the problem to the extent I have to change gear with the side of the boot as I cannot hook the boot under the selector.
Are there different size selectors avaialbe that can be fitted or can I adjust the positioning of the one on the bike so it is higher to enable me to hook the end of my boot underneath it?
Thanks
Hi, have a read of This
Must have used the search engine wrong as tried to do a search on it and it didn;t come up with anything.
I'll get on to the dealer and have it adjusted , failing that i'll become a contortionist!
Thanks!
