Pls. help me re Mikuni carb installed on a Yamaha YZ80K .... Honestly I'm new to all of this . Got the bike for my son , but since then been having a lot of problems with it . Gas leeks out on one of the tubes . I don't know what tube goes to where ... I pray you guys can help me with this....
Thank you , Peace .
" Merry Christmas to All " !
Thank you , Peace .
Not familiar with the bike or its carb but it may be leaking from the overlow its a bit of a guess really without a better description or a picture but the overflow is the lowest tube and is connected to the bottom of the float bowl and is facing rearward. The other connection (apart from the fuel feed) is the air vent tube and is connected somewhere on the side of the carb. If it is leaking from the overflow then you will need to check the condition of the shut off valve and the float height setting (which i dont know) for this bike.
Merry xmas
...Paul
Merry xmas
...Paul
Sir Paul thank you for the tip ... Sir here are some pics of the carb installed . I hope this could help to determine what type, kind of carb .
Again thanks and " Merry Christmas to you and the family "
Mabuhay !
Like " Merry Christmas all around ! "
