December 18, 200915 yr hi every1. i have a leaking crankcase seal on the stator side of my 98dt200r. i m wondering if the seal can be changed without splitting bottom end. if any1 can help would be much appreciated.
December 18, 200915 yr hi every1. i have a leaking crankcase seal on the stator side of my 98dt200r. i m wondering if the seal can be changed without splitting bottom end. if any1 can help would be much appreciated. Yes both the crank seals can be changed without splitting . For the stator side you will need a flywheel puller size 27x1 LEFT HAND THREAD , it's a quick job . Bob C
December 18, 200915 yr Author [quote name='bob-c' date='18 December 2009 - 07:13 AM' timestamp='12611 20431' post='110008'] Yes both the crank seals can be changed without splitting . For the stator side you will need a flywheel puller size 27x1 LEFT HAND THREAD , it's a quick job . Bob C thank you very much bob-c.i will have a play with it over the holidays.
