Yamaha FZR400 3TJ technical help
Hi peeples...I've an import 90's 3TJ, that has had a 1WG bottom end fitted prior to me taking ownership. Now, problem is that as there's not much on the net for the 3TJ, there appears to be even less for the 1WG.
My problem is that i can't locate the oil pressure sensor on the engine...this maybe because it doesn't have one...or its possibly located under a cover or in a less obvious place...and the spare wire i have on the loom and hence the panel light, isn't connected to anything so i've no way of knowing when riding if i've low oil pressure.
Can anyone help, tell me where the oil sensor is if there is one?
Also, i've now nearly fully stripped the bike down and rebuilt it and amazingly it works...so i've come accross quite a few problems in the past few weeks so if i can be of any help to yoo's...drop me a line.
Many thanks and keep sunnyside up...rubber side down!!!
