Air mixture problem?
Hi can anyone please help
i have 1990 xj600 roadster
only bought the bike recently so i dont know the bikes history
the bike didnt have a air filter and the filter housing was broke so i got new ones
now its very difficult to start the bike and it seems to lack power
best way to start it is to remove the seat and cover the airintake completely with ma hand
then it seems to start ok but it rouns really rough untill running
new plug made no difference
it seems to run ok once heated although when pulling away if you give it too much throttle
it seems to hesitate
any advice is well apretiated
cheers
cheers
sounds like too much air, is the filter the correct one and seated properly? another thing is to ckeck the carbs choke mechanism is working correctly, can you see the butterly valves operating?
hi thanks for reply
yep the filter is in nice and snug
sorry i do not know how to check the butterflys
hi thanks for reply
Me neither, not familiar with the bike, but......
If you remove the filter is it possible to see down to the carb inlets, then operate the choke and you will see them closing
or if you cant, then can you see anything happening around the outside of the carbs....linkages moving for example?
hi no sorry i can not seeinto the carbs from were the filter is as it is blocked off
when you pull the choke out everything seems ok visualy
well its acting like the choke isnt working, you are doing the choke manually when you put your hand over the inlet like you said earlier.
If its a case of you cant get your head in the airbox...can you use a torch and a mirror to see with?
ok i put my hand in had a feel there is 4 cylender like valves that i can push up with ma fingers is this what am looking for?
No they will be the throttle slides, the choke butterfly valve will be behind that (engine side) I suppose what i said earlier is wrong then as you wont see them by looking down the carb...just have to watch the linkages then...check they are operating properly
hi ok i took carbs off everthing is moving as should be
i put everything backtogether still difficult to start :(
There could be lots of things wrong - are the rubber manifolds between the carbs and head in good condition? Try xjbikes.com for everything XJ. I joined in the summer and there is LOADS of info on starting bikes, rebuilding carbs etc.Ideal for older XJs.
A previous owner had used some ladies tights instead of an air filter on my bike!!
