December 9, 200916 yr hi can anyone please tell me best way to ajust a new clutch cable i have it fitted just need the info how to set it up many thanks
December 9, 200916 yr Welcome corby . is that beside York ? , Now the cable " has it just the adjuster at handle bar end ? if so , U shud leave about 5 mm slack . between lever and stop, check to see thers no slip .[ on run] if thers slip , u may have to adjust down on the pushrod in side casing[ usually found in front of sprocket] slacken lock-nut . and back off screw, then screw in till just touching pushrod, tighten lock nut. , am asuming this model is the same as conventional clutches ,
December 9, 200916 yr Author hi bud corby just outside kettering ok ajusters on both end traditional on the hand lever and 2 nuts either side the bracket lower end am sorry can you explain again for me? am stupid lol ive got the cable on but am sure its not ajusted correct as its dificult engaging neutral now
December 9, 200916 yr ive got the cable on but am sure its not ajusted correct as its dificult engaging neutral now Dragging is the term,,,,, u need to adjust it up a little [ie tighten the screw . handle bar end, if this dont work . back the handle bar srew off totaly, [end of thread.] adjust bottom end , tighten. then adjust top end till clearing[ no dragg,] again shud be 5mm minimum slack at top,, Phew long winded ikno...
