Hi guys, I've just put a Malossi big bore kit on my YQ50 as well as a 22mm malossi carb, leo vince exhaust, malossi variator and clutch and Malossi foam air filter. A mechanic I spoke to said that I should get a different air filter for it, as in Australia, our dust is much finer than in Europe and that he's always seeing blocked carbs and other problems caused by European air cleaners. Do you think there is any truth in this? If so, what other filters can you recommend that will fit and won't restrict air flow too much?
