January 17, 201016 yr I'll have the engine up on a stand this week, and i'll take a look at what it would take to make an adapter. I don't think it should be that hard. If i can find a solution, and a place to make some at a decent price i'll let people know.
January 17, 201016 yr Moderator just had a quick sqidge on the internet for this adapter if it is part # 99999-02290-00 then there are 2 at nwvintage got the info here
January 17, 201016 yr i wish i could find a picture of that part so i knew exactly what it was. i may still make my own, simply because i'm an engineer, and designing things is what i do. That said, i'll have someone with the correct tools make it so it looks a little nicer than the engine stand mounts i made.
January 20, 201016 yr Author i wish i could find a picture of that part so i knew exactly what it was. i may still make my own, simply because i'm an engineer, and designing things is what i do. That said, i'll have someone with the correct tools make it so it looks a little nicer than the engine stand mounts i made. There was one on ebay a while a go (i missed it )- i think it looks like the filter mount with a different nipple on it -- basically the same thing only different thread - I was thinking of using the stock mount and welding another nipple on -
April 5, 201115 yr There was one on eBay a while a go (i missed it )- i think it looks like the filter mount with a different nipple on it -- basically the same thing only different thread - I was thinking of using the stock mount and welding another nipple on - That was probably me or a buddy of mine (for his 74 TX500). I grabbed on off of eBay too for my 73 TX500. There is not a filter produced by Fram, Purolator, K&N, etc etc that has the correct threads and gasket base diameter. The stock Threads are M22 x 1.5MM, they just don't make them in the size we would need to cross reference them to another filter. The adaptor kit comes with a new base, gasket, washer, and oring. The new base has a groove cut into the filter gasket mounting surface to put the oring into. Then the washer goes on next, and then the new filter. The new base has a thread of M20 x 1.5MM. Now, if you have the adaptor, you can go grab any M20 x 1.5MM filter from the auto store that will work. I used a Fram, but for the life of me, I cannot think of the number. I did not have to loosen the stator cover to get the filter off. I will update the post with the filter I am using with the adapter kit installed. *UPDATE 4/5/2011* I am using a Fram PH6607 with my adapter kit for my 73 TX500.
April 12, 201313 yr Hey guys, just bought a 73' tx500 for my first bike, and ive been restoring it. It was sitting for about 13 years. I seem to be able to find all the parts i need except a reasonable oil filter. I found this site in my searches for a solution and read about the adapters. Ive tried ebay and NW parts already. NW has original filters i believe but they run around 30$ and im not sure how many are available. There's also one on ebay but its 70$! Im looking for a more permanent solution. Does anybody know if any of those adapters or another solution is available anywhere? Any help would be appreciated! Thanks!
