1998 dt125r
ok, firstly most important, my damn rear indicators aaaah!!! i had a broken cracked taped up left hand switch gear, with, everything apart from indicators worked with it, i.e both rears would come on and one front one lol, so, i forked out £80, yes £80!!! for a new l/h switch gear, and...suprise, the problem still persists, im thinking, dodgy wiring, but now i fitted new switch, everything workes i.e lights , horn, but, only both back inidcators now, no front ones atall, so if anyones knows of any ideas? great much appreciated, also, looking for a good looking tail tidy for it? any websites/shops you can reccomend, and one final thing, orange fork gaiters. cant seem to find anywhere, or im just shit at looking lol. thanks for reading guys, help much appreciated :)
xx
1998 dt125r
xx
Yamabyss...a forum to speak your mind and give it LARGE!!!
Workshop...a forum to get your bike fixed ;)
Indicators shouldnt be that difficult to fix with a wiring diagram and multimeter.
Are you telling the full story? NOT LED mods?
i had a similar problem with my DT50 after i put the indicators back on after stripping it down for painting, turned out i had the indicators wired in wrong so that they were plugged into each others wiring, if you know what i mean... if you unplug the rear ones do the front ones function correctly?, and vice versa with the back ones with the fronts unplugged
ill give it a go and let you know mate.
