choppernorgate Posted November 25, 2009 Posted November 25, 2009 i used my honda blackbird and the head light bulb has gone,i checked fuse put new bulb in still the same anyone got clue high beam works n dip works
Moderator Airhead Posted November 25, 2009 Moderator Posted November 25, 2009 i used my honda blackbird and the head light bulb has gone,i checked fuse put new bulb in still the same anyone got clue high beam works n dip works Confused...what do you mean "high beam works n dip works " ,?
choppernorgate Posted November 25, 2009 Author Posted November 25, 2009 Confused...what do you mean "high beam works n dip works " ,? sorry the small bulb works the head light dont work the main or pass light works can it be the relay
Moderator Airhead Posted November 25, 2009 Moderator Posted November 25, 2009 sorry the small bulb works the head light dont work the main or pass light works can it be the relay Course it can...but there again it could be another reason, it could even be that the new bulb jou put in is no good! you really need a wiring diagram (usually found in manuals), a multimeter and an understanding of both these things to begin fault-finding properly...otherwise its just buying other bits like a relay and taking pot luck
choppernorgate Posted November 25, 2009 Author Posted November 25, 2009 Course it can...but there again it could be another reason, it could even be that the new bulb jou put in is no good! you really need a wiring diagram (usually found in manuals), a multimeter and an understanding of both these things to begin fault-finding properly...otherwise its just buying other bits like a relay and taking pot luck i will put the tester on it tomorow just wonted a lazy way out thanks
choppernorgate Posted November 26, 2009 Author Posted November 26, 2009 i will put the tester on it tomorow just wonted a lazy way out thanks thanks to you all for your help i took it to the docs he put new bulb in, no change so he put the multimetre and did just wot i did, comfirmed alls ok so he put another bulb in and yes 3 bulbs later. thought it was a loom prob: so thanks again for your help guys.
Moderator Cynic Posted November 26, 2009 Moderator Posted November 26, 2009 thanks to you all for your help i took it to the docs he put new bulb in, no change so he put the multimetre and did just wot i did, comfirmed alls ok so he put another bulb in and yes 3 bulbs later. thought it was a loom prob: so thanks again for your help guys. I used to do sparky work till i knackerd my back and if i had a quid for every time i heard 'but its a new bulb' i'd be a bloody millionaire.
choppernorgate Posted November 26, 2009 Author Posted November 26, 2009 I used to do sparky work till i knackerd my back and if i had a quid for every time i heard 'but its a new bulb' i'd be a bloody millionaire. have you not ever bought a bulb that didnt work,
Moderator Cynic Posted November 26, 2009 Moderator Posted November 26, 2009 have you not ever bought a bulb that didnt work, Plenty, it is the first thing i check EVERY time i have a light issue.
Moderator Airhead Posted November 26, 2009 Moderator Posted November 26, 2009 Good to hear its fixed That would have been the first thing I did after the new bulb didnt work ie check the 'new' bulb with the meter.
choppernorgate Posted November 26, 2009 Author Posted November 26, 2009 Good to hear its fixed That would have been the first thing I did after the new bulb didnt work ie check the 'new' bulb with the meter. i checked it with 2wires on the batery, high beam worked, they only have two pins on them bulbs so didnt know how to check the lower beam if that makes sense
Moderator Cynic Posted November 27, 2009 Moderator Posted November 27, 2009 i checked it with 2wires on the batery, high beam worked, they only have two pins on them bulbs so didnt know how to check the lower beam if that makes sense One pin for main beam, one pin for dip and the metal case acts as the earth, well kinda, modern bikes use neutral/ negative switching so you can use smaller wire and switches but you get the idea. What you did was power the dip beam and main at the same time via the common 'earth' connection.
little dave Posted November 29, 2009 Posted November 29, 2009 cynic: you have always been a dim bulb anyway...
Moderator Cynic Posted November 29, 2009 Moderator Posted November 29, 2009 cynic: you have always been a dim bulb anyway... Better that than blinded by stupidity
