November 22, 200916 yr Hi All All going to plan with my restoration of a DT250MX (1980),finished painting the engine and exhaust, new piston rings, everything polished and cleaned where needed. Boiled carb and other parts in lemon juice (without rubbers) worked a treat. reconnected the autolube set cable fitted all new pipes (clear for the one going into the carb) and bled the oil. Now getting ready to paint the front and rear fenders, which had been previously painted, paint had cracked all over, so have taken off with paint stripper. To avoid previous which would be the best type of spray paint to use, has anyone had any success/reccomendations in this. Will be painting it white. Thanks in advance.
November 22, 200916 yr Moderator Doesnt really matter but score them with medium wet / dry first, than prime, then smooth off again before top coat. It laquering it would be best to use a petrol resistant version but this is more important on the fuel tank. These are plastic and painted using rattle cans, for a DT175MX
November 22, 200916 yr Author Very nice, if mine come up that good I will be pat myself on the back. Hi All All going to plan with my restoration of a DT250MX (1980),finished painting the engine and exhaust, new piston rings, everything polished and cleaned where needed. Boiled carb and other parts in lemon juice (without rubbers) worked a treat. reconnected the autolube set cable fitted all new pipes (clear for the one going into the carb) and bled the oil. Now getting ready to paint the front and rear fenders, which had been previously painted, paint had cracked all over, so have taken off with paint stripper. To avoid previous which would be the best type of spray paint to use, has anyone had any success/reccomendations in this. Will be painting it white. Thanks in advance.
November 26, 200916 yr here in the states i think its krylon, that makes a paint specificly for painting onto plastic. its supposed to bond with the plastic molequles.
