November 22, 200915 yr Hi, I have a dt125lc when i start it it revs up way to high i tried to adjust the idle speed but it didn,t make any difference. I read somewhere that this problem could be an air leak but it ran fine before i took the carb off and i checked the inlet and it seems sealed. Could someone point me in the right dirrection as in what could be the problem.
November 23, 200915 yr Have you got the carb slide in right ? The cutaway at the bottom of the slide should face back towards the airbox.Also make sure the throttle cable outer hasn't come out of the junction box. Tony
November 23, 200915 yr Author Have you got the carb slide in right ? The cutaway at the bottom of the slide should face back towards the airbox.Also make sure the throttle cable outer hasn't come out of the junction box. Tony The bike was running fine then i ran the tank dry by accident. Filled it back up after that it started bogging down and stalled couldn,t start it. i took the carb off beacuse i thought maybe it had pulled crap into the carb cleaned the bowl put it back together still diddn,t work. Replaced the spark plug, Bingo!! It fired up first kick but reved all the way to 8000rpm. I checked the carb slide it wasn,t in the right way so i turned it round didn,t make a difference. i tried adjusting the idle speed no difference.
November 23, 200915 yr Moderator Has it got a vacuum operated tap fitted? If it has you may have made a load of work for yourself...with these taps if you run the fuel dry all you do is swith to'PRIME' after re-filling. Then switch back after a short while.
