I have just bought a winter project, 1982 Yamaha sr250, on checking the spark when I press the start button I get an immediate spark then nothing untill I stop pressing the button and then a few seconds later I get a single spark, WEIRD.
the starter motor is a little worn/slow, would I be right in thinking there's not enough turn over speed to generate a full spark? I was thinking maybe if I bump it down the road.
any help appreciated.
Cheers
Thanks guys
I sorted it now, it was the ht lead shorting out, I recharged the battery and whehey it lives!
Thanks again.
Don't spose you'd know if I need to remove cam gear to get the old rev counter cable out?
Cheers vroooOOOM
On the XT250 i had which is basicaly the same engine as the SR i seem to remember the tacho cable outer cable is held in with a circlip where it goes into the cam cover and then should pull out.Tony.
