My son (lets blame someone else...) filled our Yamaha YBR125 (2008) up and put the petrol filler cap back on incorrectly, in that there is an arrow on the cap that is supposed to point forward. Instead the arrow points at about 8 o'clock. The result is that now we cannot get the cap off with the key. They key turns but the cap does not come off.
Is it a matter of brute force and ignorance or has anyone any advice?
HI. You could spray it with WD40 inside the thread leave it to soak in topping it every now and then. then try to turn it. is that donsnt work the get a screw driver and a hammer and try to smash it round. this will destroy your cap but a least you may get it off. hope this helps
  • 7 months later...
Hi, This same thing just happened to me!!!
So how did you manage to get it off? brute force or some special technique?
Please help!!!
Thanks
Please help!!!
Thanks
Mitch, send andyswarbs a PM, you will more likely get an answer to that question. ;)
