Hi all
I ride a 2001 Dragstar 125, an imported model. The speedo issue is sorted with a KPH to MPH converter. The headlight, or at least the beam was shielded with tape to go through the MOT. Does anybody have any tips to alleviate the headlight aim problem in a permanent way?
Can you not adjust the aim manually?
Should be two screws, each one controlling up/down or left/right...
Failing that, swap the reflector for a UK spec one.
Failing that, get the stick-on reflector that does the same job.
