I have a yamaha rt1 360 that lost spark I suspect it's that the points need filing. Does anybody have any idea how to get the flywheel off this thing? is there a cheap way? do i need a puller? where do I get it? also any idea on the flywheel itself is it keyed? I am afraid I will screw up the timing if i mess with it.
Welcome to the forum!
I believe the points are on the outside of this bike...which means you are removing the points assembly and then the rotor. You need a slide hammer, and not a flywheel puller, if this is the case. Pictures? :D
thanks for the welcome. I am fairly certain that the points are behind the flywheel on this one. pics soon.
