xs400 cafe process
Hey guys I thought I would like to show my progress of my xs400.
Here is the hump I am struggling with.
I was trying to cut small foam blocks and glue them together but they keep crumbling when I sand them.
This is what it looks like so far. Excuse the tank it was a 5 min bomb job to see if the color scheme is good
I think its too square?
is the hump too far back?
Ok guys I bought some foam stuff and its curing as we speak. Here is what I did...
I have a dirty work area haha.
anyways since the issue was getting a stable flat seat pan, I wrapped the seat section in aluminum foil and cut out a shape I want for the bump
Now on to the foam part. It said to wear gloves..LISTEN TO THEM! I have sticky foamy fingers!
Hump looks uneven but I can fill it out later with the floral blocks
I put a floral block on the right side cause it did not cover that section.
Now the hard part...wait 8 hours before it fully cures and I can sand to my hearts content.
Alrighty guys sorry for the long wait but here are the parts that came
The mirrors seem pretty damn solid, the clubman bars seem pretty cool but the rear sets are crap, they already have scratches on them even though they have a dull sheen and the mounting points (50mm distance) was suppose to mount without problems but the mounting holes on the rearsets have excess metal on them and they are spaced about 51mm or something.
Now here is the seat
any comments? The seat section was replaced with a cereal box since sanding the foam would take forever, also I got a friend who helped me out.
personally i would have ditched the indicators and used smaller ones elswhere or use a handlebar mounted set which show fore and aft.
you could have cut away the back bridge/seat support and cut away the plastic inner guard so you have a flatter base to work from, that way you could have put an aftermarket seat and be able to put your battery in there!!
the seat you have made looks more comfy than the standard aftermarket ones and you have done a great job there mate.
have you thought of using an xs750 tank for the cafe look. there is one on youtube and looks the dogs.
well done so far keep it up
drewps
BTW i think you can file the foam with a rasp file
drewps
"personally i would have ditched the indicators ", or cropped the stalks.
updates!
I had to take the seat the seat in the house because it was drizzling while it was curing. So here are the pics, currently it has 1 layer of glass mat (sanded down of course) and I just put a layer of glass cloth today. I plan to put 1 more layer of each.
I will prob sand it and trim it down tomorrow before I lay any more glass. Also as you can see there are indents where the shock and turn signals are. I plan on getting the small aftermarket oval type instead of sticking with those bulbous things.
