what jets do you reccomend
on my 1974 dt175 i have the mikuni carb with the round slide.
anyhow it has come time for me to buy some parts for it, float gasket, mostly.
but i figured as long as i was at it i would finally buy a main jet.
my air filter is pretty much one of the cone ones.
and when i got the carb it had a lump of lead blocking the jet intake and a regular bolt in the banjo bolt hole. (basically it had a fully clogged main jet.)
i removed the lead and fashioned a cap for the opening so as to allow fuel to be able to flow into the main jet intake area. but without a main jet installed, (never had one) it tends to run really rich, even with the throttle needle in the top notch. i want to put in a main jet assy.
which jet would be appropriate for a low restriction air intake?
I dont want to spend the money on all 3 if i can avoid it, and i dont want to run too lean, or have the same problem i do now.
my choices are 150, 160, and 170.
Hi Dave, if your bike is a DT175A the correct standard jet would be 150, you are running a less restrictive filter so that will require a richer jet, say 160. Also air density has an effect too, high altidude and hot dry climates etc also have the effect of richening further. I would go for the 160 first and do a plug chop, put the needle back to the correct clip position. jets aren't expensive anyhow so you could even buy a choice of the sizes ;)
