Dragstar choke
tonytony
This post is 5483 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
My midlife crisis came later than most so I bought a Dragstar 650
I know about bikes from many years ago so my know-how may be out of date, but here goes
I cannot move/pull out the choke cable..
The choke cable is free in it's outer cable but the lever it is supposed to move is solid it only moves about 1/8 inch
As I said I may be out of date but isn't the lever which the choke cable is attached to supposed to move because mine doesn't.
cheers
Link to comment
Share on other sites
Hmmm..... Not had to deal with chokes on Drags before...
Well first, check that it works.
Start the engine up and get it running nice and warm.
Then slowly slide the choke out - The revs should increase. If you slide the choke out quickly, the bike will probably cut out.
I'll have a gander at my 650 and see what's what.
Link to comment
  • Recently Browsing
