Hi, I have a DT125 lc3 "86" model, i can't find a drain bolt to drain the radiator could anybody tell me where to find it.
Also is the transmission oil drain bold directly under the crankcase?
Thanks in advance
I found the transmission oil drain bolt :)
Is the drain bolt for the radiator on the water pump do i need to bleed the system when i drain it.
