November 4, 200916 yr Hi all I have nearly completed a resto on my DT175A and need a blinker relay. Its a three wire type but some of the bike wreckers here are saying that I can use an after market 2 pin type because two of the wires going to the original relay are only earth wires and I could join them together if I went with the after market type. It doesn't look right to me on the wiring diagram. Would anyone have any thoughts on this as I can't find the original relay at the moment for a reasonable price. Cheers Sean
November 4, 200916 yr Moderator There is only one ground (chassis) connection on the 3 pin relay, the black wire. The brown is a +6v feed and the Br/W is the output feed to power the lamps. ...Paul
November 4, 200916 yr Author Thanks Paul, that explains the diagram perfectly to me now I maintain my search for the original relay Sean
November 4, 200916 yr Moderator Thanks Paul, that explains the diagram perfectly to me now I maintain my search for the original relay Sean Y'know though Sean, my bike (DT175MX) only has the two wires, a brown 6v supply and a Br/W output to the switch and lamps, dont see why that wont work on yours, it doesnt use a chassis connection.
November 5, 200916 yr Author Ok thanks - its worth a try. Worst case is that I earth the relay or re-earth the black wire cheers
November 5, 200916 yr Moderator Ok thanks - its worth a try. Worst case is that I earth the relay or re-earth the black wire cheers If you do opt for the two pin variety, just leave the black wire that went to the original relay disconnected, dont ground the two pin relay.
November 5, 200916 yr Have you tried Paul Goff? 4 quid plus p&p (another £1.50 in the UK, possibly a bit more for colonials) Clicky Linky Thing You're welcome
November 5, 200916 yr Moderator Have you tried Paul Goff? 4 quid plus p&p (another £1.50 in the UK, possibly a bit more for colonials) Clicky Linky Thing You're welcome Great link
November 5, 200916 yr Author Sensational..Thanks for the link I'd have to wire it upside down though coming from the land down under .......... cheers Colonial Sean
November 19, 200916 yr Hi mate, Not been on the forum for a while but saw your post. Hopefully you have it sorted by now. I replaced the relay on the 250 and tried a wrecker first for one that was original(ish). It didn't work then another place sold me a new two pin relay saying it would work. I couldn't get it and then ended up at another place where I got a new three pin one that worked fine. I could go and get the details off the bike it if you need it assuming that they'd use the same relay. Gordo
