November 1, 200916 yr I have a 1995/6 YZF 750 R with 27K on clock New emulsion tubes in carbs and just been serviced. What I would like to know is, to do the shims on this bike are they in the same position as the valve stem seals, as it burns oil which is visible by people behind me when throttle is fully opened on motorways (100+... ) Also you see blue smoke on start up of bike for a few seconds. The reason I am asking is that it was in the garage and supposingly my carb compression was low and they said they replaced the shims etc. with several gaskets been replaced. I had oil trickling from rocker gasket which they sorted a few days ago. Any help would be appreciated, thanks
