Posted October 27, 200915 yr Hi, Can someone tell me where the generator is on a 1988 tzr125? also the location of the rectifier. How do I remove the generator for repair/replacement? Cheers, Paul.
October 27, 200915 yr Author Hi, right found the rectifier and will test it tomorrow. So wheres the generator? How do i get to it? I've tested the electrical system at the battery and with the revs at 3k rpm i get 13.5 volts - so something is nackered!! is it more likely to be the rectifier or generator? Cheers, Paul.
November 1, 200915 yr Moderator Hi, right found the rectifier and will test it tomorrow. So wheres the generator? How do i get to it? I've tested the electrical system at the battery and with the revs at 3k rpm i get 13.5 volts - so something is nackered!! is it more likely to be the rectifier or generator? Cheers, Paul. that's not too bad 13.5 volts, it is charging. what is the problem exactly? maybe need a new battery if its not holding a charge!
November 6, 200915 yr The generator is under the LH engine side cover but you will need a proper flywheel puller to get the rotor off.You can check the coil resistances by just disconnecting the multi plug from the generator without removing the flywheel.Tony.
