dt 125r running problems and powervalve ratte/knock
DT 125R MAN
This post is 5495 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
afternoon all,
right ive finally got my power valve working a bit better :) when i turn the key the powervalve sets up and is inline with the dot/hole on the head ok and when the bike it running it move with the revs ok but when the revs pick up a bit and the power valve goes about a centimeter clockwise a rattling/knocking noise appears :\ is this normal? im guessing the powervalve cant hit the piston because i wondered if that was the noise?
also i cant seam to get the bike to run right it will start fine on the choke and idle at about 2k and when warmed up ill take her off the choke and the revs pick up to about 2.5k for a few seconds and then the revs will start to slow down untill it totaly dies and if i go back onto choke will bring revs up to 2k again but after a while it will cut out! but if i keep the throttle on a little it will stay running fine:/
any one got any ideas? cheers
Link to comment
Share on other sites
afternoon all,
Your piston cannot hit the powervalve, thats the easy bit done. The rattling/knocking sounds like dettonation, added to what sounds like some carb problems. Favorite would be the main jet blocked as the choke helps things along.
Looks like she's asking for a bit of TLC.
Link to comment
did not think it could hit was just checking tho so thanks for clearing that up :) is there any way to stop dettonation? ive only just had the engine back from a rebuild its not even done a mile yet :/ cheers
Oh, how thourough was the rebuild? and was it done by someone who knew what they were doing/ were recomended to you by someone?
If it was a complete rebuild then the engine builder should have set the ig timing before they put the flywheel back on they should also have re-bushed/decoked the powervalve if it was required. There should be no worries about the motor IF its been rebuilt properly.
As far as the carb goes, take it off and give it a thourough clean internally checking all the airways and jets are clear. Set the float height and then re fit it. Use good fuel fresh from the pump (or no more than a couple of weeks old) and start it again. If you still get all the horrible noises i'd consider taking it back to the person that 'rebuilt it'.
Link to comment
it was a guy who used to work for a motorbike garage for many years! i had a new piston rings rebore new big end and small end bearings :/
ok cheers ill get on with the carb now
Did he sell them or fix em :lol: Sorry thats not fair.
If you have had piston,rings,bore and CRANK bearings done then there shouldn't be anything to worry about inside. It should all have been delt with in the build.
Check out that carb.
Link to comment
My bike used to rattled... once it seized. I done the top end rebuild which took most of the piston slap away but there may have been a little play in the crank (irrelavant here).
Was it done or did he say it was done, (2 difrent things).
Link to comment
yeah it has been done because for a start the old piston had smashed :(
Link to comment
right ive cleaned out the carb with some carb cleaner used a whole can to make sure its nice and clean! but still wont run with out choke other thing ive just noticed is the boost bottle is missing he has just pluged it up :/ could this be why i wont run right? cheers
Link to comment
  • Recently Browsing
