October 20, 200916 yr any1 help iv got a dt 125 starts 1st time,wen i pull off its ok but wen i try to pick up more speed it starts to splutter any suggestions
October 20, 200916 yr any suggestions Hi Scram-bled .. better if posted in workshop section, "Ryan09" is the DT125 boffin .
October 20, 200916 yr If its the powervalve the revs would just die when going into higher revs? right? Sounds like a blocked jet to me, might be worth seeing if the carb needs a clean? Thanks for the compliment blackhat
October 20, 200916 yr Author ye tryed the carb m8 still no luck it ticks over mint,even changed the airbox to see if that was the prob still no luck any ideas cheers
October 20, 200916 yr Is it spluttering as in losing revs and bogging or just not reving past a certain point?
October 20, 200916 yr Author its a 2000 i pull of fine but when i accelerate it looses revs and bogs ??
October 20, 200916 yr If its not a blocked main jet or an extremly dirty air filter then the only other thing there is, is the pv like og said (Does seem a common thing on DT's), might just need tweaking, cleaning and re adjusting. Its a really simple engine and not alot can go wrong with them tbh.
October 20, 200916 yr Author ye cheers will try that it splutters before the pb kicks in so im nt sure thanx
October 21, 200916 yr Itmight just be the bike struggling to turn the pv, if you do take it out to clean just make sure you lube it when you put it back in as you dont want much friction there.
October 21, 200916 yr Author could well be that m8 cheers for the advice ill get bk to you if u think of anythink else wb thanx
