dt125
scram125
This post is 5513 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
any suggestions
Hi Scram-bled ..biggrin.gif better if posted in workshop section, "Ryan09" is the DT125 boffin . wink.gif
Link to comment
Share on other sites
If its the powervalve the revs would just die when going into higher revs? right?
Sounds like a blocked jet to me, might be worth seeing if the carb needs a clean?
Thanks for the compliment blackhat ;)
Link to comment
Is it spluttering as in losing revs and bogging or just not reving past a certain point?
Link to comment
If its not a blocked main jet or an extremly dirty air filter then the only other thing there is, is the pv like og said (Does seem a common thing on DT's), might just need tweaking, cleaning and re adjusting. Its a really simple engine and not alot can go wrong with them tbh.
Link to comment
Itmight just be the bike struggling to turn the pv, if you do take it out to clean just make sure you lube it when you put it back in as you dont want much friction there.
Link to comment
