hi all,
right i have a dt125r and the powervalve is a bit stiff on it what can i use to greese/lube it up? cheers
hi all,
You sound like your expecting a can of squirt to fix it? Generally powervalve assembalys fall to bits and rattle about, so are you on about the cable, servo?. If you are refering to the powervalve its self put your hand in your pocket for a set of o rings and de-coke it, if it is coke'd up you better be doing the top end too, and the pipe.
