October 18, 200916 yr i recently brought a 1995 exup1000. a little knocked and banged but mint engine. anyway the foot bracket is damaged it moves every time i press on the rear brake and my brake lights stay on. i have to kick it to get it to go off. cant really afford a new one as the cheapest price i can get is £69. i know daft. does any one know how i can stop it from moving untill i can afford a replcement? cheers.
October 18, 200916 yr tighten up the nut,or mig weld the foot peg.the sticking brake ,you can try a good dowsin of wd40.
October 19, 200916 yr i recently brought a 1995 exup1000. a little knocked and banged but mint engine. anyway the foot bracket is damaged it moves every time i press on the rear brake and my brake lights stay on. i have to kick it to get it to go off. cant really afford a new one as the cheapest price i can get is £69. i know daft. does any one know how i can stop it from moving untill i can afford a replcement? cheers. The bracket you're talking about may not be damaged, the foot peg may have just rattled loose. You can tighten it by removing the bracket from the bike & tighten the allen bolt that passes through the back of the plate & holds the pedal & peg together (be careful as you may need to unhook the rear of the pedal from the rear master cylinder). Oh yea you might as well grease between the peg & pedal to make sure it works freely before tightening the bolt. Hope this helps.
