Posted October 18, 200916 yr Hi, have just got my DT175MX running again, see previous threads, and I keep feeling for a bigger gear when riding in top. As far as I know I am on standard chain sprockets for a 125. Is the 175 different and if not which way do I go, bigger front sprocket or smaller rear. Anyone know, done it before? Thanks Phil
October 18, 200916 yr Moderator Hi, have just got my DT175MX running again, see previous threads, and I keep feeling for a bigger gear when riding in top. As far as I know I am on standard chain sprockets for a 125. Is the 175 different and if not which way do I go, bigger front sprocket or smaller rear. Anyone know, done it before? Thanks Phil Hi Phil, standard front for a 175 is 15 teeth, strangely enough standard for a 125 is 16 teeth so that is higher geared. However you can get standard +1 or +2 (for higher gearing), and aso -1 or -2 (for lower gearing) from wemoto for example, the only problem is the postal strike! Wemoto DT175MX Parts
October 18, 200916 yr Going 2-3 teeth larger in the front or smaller in the rear should gain you about a 5 mph increase in top end speed. Hope this helps.
October 18, 200916 yr Moderator Going 2-3 teeth larger in the front or smaller in the rear should gain you about a 5 mph increase in top end speed. Hope this helps. 2 teeth bigger will take top speed from 65 to 73.5 mph
October 19, 200916 yr 2 teeth bigger will take top speed from 65 to 73.5 mph Yip all very well, but wait till u drive into the wind ,, i"tl kill ur little stroker ,
October 19, 200916 yr Moderator Yip all very well, but wait till u drive into the wind ,, i"tl kill ur little stroker , Aahh well....Just put a Garelli badge on it
