Posted October 16, 200916 yr Hi If you have a road registered WR400F from circa 1999, I'm wondering if you could take a look at your V5 and help me fill out the following boxes on my application form for a first registration (I have some of the values already from the web, but I'll reproduce here if you can check it?): Variant: Version: Length: 2275mm HC g/km or g/kWh: Unladen weight: 113kg Number of Seats: 1 Max Net Power: 35.3kWh Width: 835mm NOx g/km or g/kWh: Power/Weight ratio: 0.312kW/kg CO2 g/km: Particulates (pm) g/km or g/kwh: CO g/km or g/kWh: HC + NOx g/km: Stationary Sound Level dB(A): Engine Speed Sound Level: Drive-by Sound Level dB(A): Thanks in advance for any info you can give. I'm sure that not all this info is on the V5, but if your V5 shows anything I don't have or disagrees with any of the values already entered, or if anyone can think of another source for this info please let me know! Cheers! cj
October 16, 200916 yr Moderator Hi, some of the riders at my local TRF (Trail riders Fellowship) group use them I think, why not send them an email and ask there [email protected] ...Paul
