Posted October 15, 200915 yr help i need to get a manual for an xvs 125(2000) the rear cam siezed and sheard the cam sprocket bolt i need to know how to set the rear cam up and set timing,but have been trying to get a service manual and have been told unobtainable by 1 dealer and back order available 2010 by another can any1 help please
October 15, 200915 yr Moderator Hard to find but weve had this before, your email? I will send you one
October 16, 200915 yr Author Hard to find but weve had this before, your email? I will send you one hi thanks my email address is [email protected]. i have been searching for 1 of these for ages,but must disagree with you regarding the bloke who invented decorating as i work for a paint manufacturer.
October 16, 200915 yr for anyone else who wants one, try: http://www.yamahaclub.com/forums/topic/13057-how-do-i-post-a-workshop-manual/page__hl__xvs125
July 15, 201510 yr I know it's an old thread but does anyone still have a link, or would be able to email one?Got the owners manual but need the workshop or Haynes style one for xvs125. Thanks.
July 21, 201510 yr I have the full manual printed out into a large ring binder folder where abouts are you
July 22, 201510 yr Bit of a trek I fear, down near Brighton.I think I may have solved the problem now but thanks anyway, much appreciated.
April 3, 20205 yr Hi, I know this is but of an old thread but need some assistance. My xvs 125 is lacking power and I suspect the pickup coil to be faulty or out of resistance, does anyone here knows what the reading should be when checking the pickup coil? Had to do a no-2 cylinder rebuild after the cam shaft driven gear rocked loose and came off.. after the rebuild it's not been right? But she has good compression, timing is spot-on, valve clearances seem good but will take measurements for those as well so I can reference to mine to be doubly sure. If those two I've asked about match others readings/measurements then the only other thing I can think of it being us the ICU/ECU Can anyone offer any help on this? Thanks in advance!!
April 3, 20205 yr Disconnect the pickup coil coupler from the harness Red probe on the green/white Black probe on the blue/yellow Should read 192-288 ohms @ 20C
