decompresstion
on the jug of the dt400 does the valve on the front work like the newer powerban on my kx, and how does it effect the performance?
Aye popalong [ stocking] - u shuda posted this in Workshop" That is an auto-matic Decomprssr, works of kickstart , cable attached. makes no differece to running , is meant to aid starting, But in My opinion its anoyying , as it lets go wen on down-stroke . , mad.gif
Sorry new to this club only two days, and was on here about 10 hours reading,
atempting to restore this bike back to next to new.gonna be a long prodject, thanks for the help.,
Hi again pippy- Got ur P.M. about the perfomance, If its hitting the red-line at 70 mph. the gearing is too low.[ sumone has dropped the front sprocket a few teeth]
Standard sprocket size is 15 tooth front --42 rear . That should pull 80 + And not quite hit the red-line.
I run 16 tooth front . its better for cruising[ thats if u call 65 mph cruising]biggrin.gif
I tried a 17 tooth , but i wudna advise that . u are for-ever kicking down box . esp when windy . cool.gif
