xj600s 1996
I have recently brought the above, can someone tell me please what the fuel tap positions are as the plate is worn and unreadable
many thanks
Arrow headed tap-down is ON
-up is RESERVE
-horizontal is PRIME
give the marking plate a good clean with meths and toothbrush (an old one is best for this !)
let it dry, paint with white nail-varnish or tippex, after this has dried polish the excess off the plate with fine wire wool :mellow:
many thanks
Many many thanks, that helps 100%
It will also help to turn the plastic tap occasionaly from on to reserve and back again. I didn't for a couple of years and when I did run out of fuel and tried to switch to reserve the tap had seized up and the plastic tap cracked and broke off. Luckily I was at work and used a small spanner but if I had been in the middle of nowhere I dread to think what might have happened. knowing my luck two cars would come along at the same time, a beutiful blonde without a spanner and a camp gay with a spanner.
