Hi All
Bike: Yamaha DT 125R (2006 reg)
After having a bit of an accident, the left hand side of the handle bar was hit and it damaged the clutch switch (The clutch lever is equipped with a clutch switch, which is part of he ignition circuit cut-off system.)
The clutch lever it self is fine, the problem is when you put the bike in gear the engine switches off.
Seems like the clutch switch (part of he ignition circuit cut-off system) is just a bit of metal next to the left hand grip but i have no idea in what positions it should be.
Anyone have any idea how I can fix the clutch switch or how i can disable the clutch switch (part of he ignition circuit cut-off system) so that the bike does not stall when i put it in gear????
Cheers
