September 24, 200916 yr hi, ive got a dt 125 and ive got a ratterling noise when the bike is ticking over, first of all we thought it was the top end bearing so we had that changed but its still making the same noise, does anyone have any ideas on what this could be. thankss =]
September 27, 200916 yr have you checked gearbox oil level is correct? also could be bottom end bearings or main crank bearings ;-)
September 27, 200916 yr Author have you checked gearbox oil level is correct? also could be bottom end bearings or main crank bearings ;-) gearbox oil is fine and okay thanks was given some advice by a garage that the gudgeon pin might make that noise so my dads going to change that and then we'll go from there if it still makes the same noise, thank you
