September 24, 200916 yr Me again are the bars on the custom dragstar as wide as the one on the classic ?
September 25, 200916 yr Actual width (ie length from tip to tip), held length or the pipe diameter? Actual - Not sure, actually.... Held - No, the Custom is set wider. The Classic is closer to your body. Diameter - I believe they're both yer standard 22mm. Come round for a cuppa and we'll compare
September 25, 200916 yr Author The bars are to wide from handle bar grip to handle bar grip for me, they are about 83 cm across the bars are 25 mm diameter
September 28, 200916 yr Then the Custom bars will be wider, I *think* you'll find. Try some Virago bars...
