September 21, 200916 yr when following drewpy home the other day the bike seemed to snatch or slip a few times as i hit the power band ,what may be the most likely cause.
September 21, 200916 yr drewpy was trying to lose you. that "slipping" was you hitting the oil patches he was laying out to slow you down. (he modified his scottoiler to lay slicks.)
September 21, 200916 yr Moderator Check your chain slack and check your chain and sprockets are'nt worn out.
September 25, 200916 yr Author and a slack arse!! hey watch yourself,that kind of reply is reserved for joshua2 only.
