xt125x supermoto not ideling
okay i picked up a xt 125 x supermoto a few days ago on an 05 plate and it was running fine yesterday i put it in the shed and next day it wouldnt idle with out the choke on or keeping the revs on 2000rpm it idles at 1000 rpm and cuts out straight away
can i adjust the idle speed to fix this??
how do i get to the adjuster screw?
if the jet was blocked would it still tick over with the revs a 2000?
also when i turn bars fully left the neutral light goes out, why is this?
anyone got a link for the manual for it?
thanks for any replys
  • 1 year later...
I know this is way old but anyway i cant help with the idleing problem but the neutral light it is because a wire is snapped proberly in the wiring loom where it touches the front of the frame this is a weak point for most xt 125 s i found this out when about 10 of mine had snapped in that place try there :)
