Posted September 18, 200915 yr Hello guys, Ive got my module 2 test on Wednesday and just wondered if anyone has recently passed and how it went. Any advice would be appreciated. Regards. Derek.
September 18, 200915 yr Moderator Good luck on Wednesday derek, Jesus was a boy when I did mine so not much use to you
September 19, 200915 yr Good luck on Wednesday derek, Jesus was a boy when I did mine so not much use to you I bet Pontius Pilot hadn't even earned his wings at that time.
September 19, 200915 yr remember to shoulder check every time you pull away, and always pull away with your left foot down, u get done for not being able to use both brakes when u pull away cause apparently you have less control :/ and when u pull over behind a parked car, put the bike back in gear before you indicate out or youll get a minor or a fail for slowing down other road users good luck
