September 18, 200916 yr can any one tell me how to adjust the float to the right level on my yamaha xt125x as i had a problem with fuel leaking so cleaned carb and all nearly fine but think i,m not getting enough fuel now or to much. plus when i bought bike oil servce light on owner says oil changed but cant get rid off service light. says only a yamaha dealer can do it is that true thanks alot
September 21, 200916 yr can any one tell me how to adjust the float to the right level on my yamaha xt125x as i had a problem with fuel leaking so cleaned carb and all nearly fine but think i,m not getting enough fuel now or to much. plus when i bought bike oil servce light on owner says oil changed but cant get rid off service light. says only a yamaha dealer can do it is that true thanks alot hi there my servise light came on a little while ago i couldnt be bothered to servise it so i decided to turn the servise light of myself i just had a guess on how to do it and it worked so if u want to give it a try on urs what i did was i turned the ignition off i held the blue mode button then turned the ignition on i kept hold of it until it flashed and then it was reset
September 26, 200916 yr Author hi there my servise light came on a little while ago i couldnt be bothered to servise it so i decided to turn the servise light of myself i just had a guess on how to do it and it worked so if u want to give it a try on urs what i did was i turned the ignition off i held the blue mode button then turned the ignition on i kept hold of it until it flashed and then it was reset hi thanks for getting in contact idea sounds good to me. shell try it on way to work
September 26, 200916 yr Author hi thanks for getting in contact idea sounds good to me. shell try it on way to work done what you said worked a treat thanks again .only one problem left now. might have to track down a workshop manual
