Posted September 16, 200915 yr Well to start off I have this Yamaha 1976 I believe, 175 (171cc) Enduro. I just got the engine running, I have gas, but I don't know what kind of oil the engine & the What kind of oil do I use for the 2-Stroke? Please help me, I just need to know about the engine, What oil's it uses.
September 16, 200915 yr Well to start off I have this Yamaha 1976 I believe, 175 (171cc) Enduro. I just got the engine running, I have gas, but I don't know what kind of oil the engine & the What kind of oil do I use for the 2-Stroke? Please help me, I just need to know about the engine, What oil's it uses. Hello: I use (Castrol power1 TTS 2T) Synthetic two stroke oil In the 'autolube' tank under the seat, for the gear box I use(Halfords branded) 10/40 Motorcycle/scooter gear oil. For the gear box oil avoid motorcar oils as those oils contain friction inhibitors and other additives that will make the clutch slip
September 16, 200915 yr Author Hello: I use (Castrol power1 TTS 2T) Synthetic two stroke oil In the 'autolube' tank under the seat, for the gear box I use(Halfords branded) 10/40 Motorcycle/scooter gear oil. For the gear box oil avoid motorcar oils as those oils contain friction inhibitors and other additives that will make the clutch slip Aww Thank you so much!! Thats all I needed to know
