hello,some one out there should know how i can get my both my headlights to work together whether on dipped or main beam fzs fazer 98 model,thanks
You would have to take the low beam wire and put a 4 way connector on it. To that 4 way connector you would plug in the positive from the left headlight and the right headlight, then on the 4th connection you would plug in the high beam wire.
Do a google search. I know a conversion kit used to be available that had a small loom and the relative bulbs and connections etc to make it work.
thanks 4 imfo m8,much obliged
hi m8, i havnt a clue what you do,if i had a diagram that might help.thanks
