Posted September 15, 200916 yr hello,some one out there should know how i can get my both my headlights to work together whether on dipped or main beam fzs fazer 98 model,thanks
September 17, 200916 yr You would have to take the low beam wire and put a 4 way connector on it. To that 4 way connector you would plug in the positive from the left headlight and the right headlight, then on the 4th connection you would plug in the high beam wire.
September 17, 200916 yr Moderator Do a google search. I know a conversion kit used to be available that had a small loom and the relative bulbs and connections etc to make it work.
September 19, 200916 yr Author Do a google search. I know a conversion kit used to be available that had a small loom and the relative bulbs and connections etc to make it work. thanks 4 imfo m8,much obliged
September 22, 200916 yr Author You would have to take the low beam wire and put a 4 way connector on it. To that 4 way connector you would plug in the positive from the left headlight and the right headlight, then on the 4th connection you would plug in the high beam wire.
September 22, 200916 yr Author hi m8, i havnt a clue what you do,if i had a diagram that might help.thanks
