Posted September 13, 200916 yr Tacho not working, replaced tacho so can probably discount that being at fault. Does the tacho receive its pulse from an ignition coil or the CDI Unit? One of my coils has way too high secondary resistance so have ordered a new one, that should cure the rough running but I don't think that is the source of the tacho problem. Any ideas welcome Cheers Peter
